Author: Subject: Aluminium
12a RX-7
posted on 1/1/05 at 07:16 PM Reply With Quote
Aluminium
Wanted ~
Aluminium tube or pipe with an ID of 42mm or as close as possible to this. Wall thickness must be >2mm around 300mm length required (or 4 off >75mm long)
Thankyou ~ Mike
paulf
posted on 1/1/05 at 08:41 PM Reply With Quote
That is about the dimension of aluminium scafold tube.I have used offcuts in the past and it had a bore of just over 40mm and wall thickness of 4 or 5 mm.
Im sure there must be a local building site with some lying around.
Paul.
mangogrooveworkshop
posted on 1/1/05 at 10:23 PM Reply With Quote
TV mast tube cheap as chips or the metal supermarket
the plumbers use that size check out http://www.lawtontubes.co.uk/PLUMBING_spec.htm
And get the local plumb supliers to get ya some Chrome plated
Or Merlin motor sport http://www.merlinmotorsport.co.uk/pdf/31.pdf.
is it merlins website or moz thats giving the 404
[Edited on 1-1-05 by mangogrooveworkshop]
12a RX-7
posted on 1/1/05 at 11:10 PM Reply With Quote
can't use the copper stuff as its being TIG welded to an aluminium flange
Thanks for the links. I have a few places locally to ring on tuesday but though I'd try and see if anyone had any or more ideas.
Volvorsport
posted on 1/1/05 at 11:38 PM Reply With Quote
ASC metals , have always done the job for me - and im assuming your somewhere close ?
www.dbsmotorsport.co.uk
getting dirty under a bus
12a RX-7
posted on 2/1/05 at 05:34 PM Reply With Quote
yup that was the plan
does anywhere local do Tig welding ? was thinking of trying Keweld
12a RX-7
posted on 4/1/05 at 10:26 PM Reply With Quote
sorted, got it from Steve at
www.mailordermetals.co.uk
ASC metals were very well priced and helpfull but only wanted to sell me 5 metres, which would have been OK but I opted to buy just 2 feet instead.
Thanks ~ Mike
[Edited on 4/1/05 by 12a RX-7]
Mark Allanson
posted on 4/1/05 at 11:21 PM Reply With Quote
Just make your own out of bodywork ally Rescued attachment Home made tube.jpg
12a RX-7
posted on 5/1/05 at 05:49 PM Reply With Quote
not easy to hold a good roundness tolerance doing that though
