starterman
| posted on 18/9/19 at 08:02 PM |
Cosworth rear hubs
As per the title I'm after a pair of cosworth rear hubs.
Mike
flanders
| posted on 19/9/19 at 10:44 AM |
I have a pair of sierra disc brake hubs £50 plus post
| posted on 19/9/19 at 02:12 PM |
Is there something different between normal disc brake rear hubs and Cosworth rear hubs?
djtom
| posted on 19/9/19 at 03:16 PM |
Cosworth ones have extended "ears" for the brake caliper mount - this facilitates the fitting of the larger discs used on the cosworths I
believe.
| posted on 19/9/19 at 03:37 PM |
believe.
OK - makes sense - more power needs better brakes!
Given the low weight of a 7 type car do you need Cosworth brakes on the back?
I used drums on my MK Indy and never had any issues. I wasn't racing or hill climbing just road driving.
T66
| posted on 19/9/19 at 04:53 PM |
Most of the brakes we use here, are for cars much heavier than our kit cars, ie Ford based discs/drums from Capri/Escort/Sierra.
starterman
| posted on 19/9/19 at 05:41 PM |
Iam changing to a 7.5" LSD from a cosworth. I've bought new driveshafts and CV joints but the hub from the standard push in shfts
doesn't fit. The splines are too small and the bearing carrier doesn't fit. Hence the need for cosworth hubs etc.
Mike
[Edited on 19/9/19 by starterman]
starterman
| posted on 19/9/19 at 05:42 PM |
It's not about the brakes, it's just about being able to use the LSD.
