Author: Subject: Engine to Type9 cover plate
HOL
posted on 16/6/09 at 08:05 AM Reply With Quote
Not sure of the official term, but I am after the one of the plates that fits between the Type 9 Box and the engine.
They never made one for the Zetec, so a Pinto or CVH one would do.
I tried making one out of ally and nearly got there – then cut a bit too much off. 
RoadkillUK
posted on 16/6/09 at 08:42 AM Reply With Quote
Start again using thin steel sheet, then if you cut too much off ... you can weld it back on again. We had to make our own it wasn't too difficult, just make one from card first.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
big_wasa
posted on 16/6/09 at 09:02 AM Reply With Quote
Even if you get one it will still need a bit welding on.
Ive made a couple and modified a couple. If you have power tools / air tools its even easier. Mark out all the holes in a sheet of tin and bolt it to the gearbox then trim off the out side with a nibbler.
posted on 16/6/09 at 10:24 AM Reply With Quote
My zetec did came with one.. just had to cut a lump out at the bottom where the starter is.
