Author: Subject: Pinto DCOE Manifold for 45's
omega0684
posted on 14/2/10 at 05:44 PM Reply With Quote
Anyone got one they don't want/need, beer tokens waiting,
mcerd1
posted on 14/2/10 at 09:43 PM Reply With Quote
you seen this one Alex ? linky
omega0684
posted on 14/2/10 at 09:50 PM Reply With Quote
yup but if he thinks im paying £50 for it he can jog on!
mcerd1
posted on 14/2/10 at 09:52 PM Reply With Quote
so what did you say when you saw the price burtons are asking for new ones :lol:
ps- I'm still keeping an eye open for a BGH box for you.....
[Edited on 14/2/10 by mcerd1]
omega0684
posted on 14/2/10 at 09:56 PM Reply With Quote
got a box now! just eye-ing up one of the fuel tanks scruffy is putting together on the DROC
PS Burtons can Swivel
[Edited on 14/2/10 by omega0684]
mcerd1
posted on 14/2/10 at 10:02 PM Reply With Quote
what kind did you get in the end ?
(I'm going to have to give burtons even more money tomorrow - I need another head gasket )
omega0684
posted on 14/2/10 at 10:08 PM Reply With Quote
i got this one
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=8;t=77 580;hl=gearbox
i have a screen on its way as well and new engine!
boggle
posted on 14/2/10 at 10:21 PM Reply With Quote
can you not make your own manifold?
u2u me for details
mcerd1
heads a stock EFI but with bronze guides, 3 angle valve seats and a little skimmed off
just got a piper 285 cam for now
the bottom ends bored out to 93mm with forged pistons, cossie crank/con rods, steel flywheel - all ballanced and good for 9k+ rpm (the head will limit that for now)
and I'll be running all that on ZX9R carbs + megajolt - so it shouldn't be far off the spec of your before your EFI upgrade
might do some porting / big valves / lumpy cam..... later on once its been on the road a while
(I guess EFI is an option - but I still like carbs better )
...or I could swap to an NA cossie head
but I'd need new pistons for that to keep the CR up, new manifolds and the heads arn't cheap either so that'll have to wait
omega0684
posted on 14/2/10 at 10:29 PM Reply With Quote
Can't weld im afraid i would quite like one that will be matched up to the throttle bodies and to the head but imagine this would cost me a pretty penny or two!
Rob, what engine setup run running, i know its pinto but what spec? or are you going to decide to go cosworth?
mcerd1
posted on 14/2/10 at 10:44 PM Reply With Quote
^^^ opps - I hit edit instead of quote
omega0684
posted on 14/2/10 at 10:48 PM Reply With Quote
stock head, 42mm inlets and 36.1 exhausts on a EFI head?
i bet that will change before the end of the year!
my prediction: full EFI set up with OMEX or Jenveys! Full race spec head with big valves, major porting and VERY LUMPY Cam ,My crystal ball is misting up now, i'd better put it away
mcerd1
posted on 14/2/10 at 10:56 PM Reply With Quote
yeah same as the carb'd ones - its just the ports that are different
I doubt it, I've got the head done now - my plans don't change much once I've got the bits
boggle
posted on 14/2/10 at 11:18 PM Reply With Quote
could probably get you a custom one made for around £120 all in....
u2u me for details
posted on 14/2/10 at 11:24 PM Reply With Quote
Originally posted by bogglecould probably get you a custom one made for around £120 all in....
Knock the 1 off the front and you might be in the ball park
boggle
posted on 14/2/10 at 11:37 PM Reply With Quote
he would have to supply the drawings and material for it to be that cheap
u2u me for details
omega0684
posted on 15/2/10 at 08:44 AM Reply With Quote
this could be do-able, you any good with a tig welder?
boggle
posted on 15/2/10 at 10:05 AM Reply With Quote
i am.......
u2u me for details
