JeffJeffers
| posted on 1/6/11 at 09:46 PM |
Washer thing
I'm after something like in the picture below but I'm not sure what to search or where to get them from.
The larger step wants to be 12mm then the smaller part 10mm with a 6mm hole in the middle.
Any help would be appreciated
mcerd1
| posted on 1/6/11 at 09:55 PM |
most folk I know would call that a 'top hat' washer/spacer/bush
what heights do they need to be ?
how many do you need ?
what do you want them made of ? (steel, alloy, plastic, brass......)
dave-69isit
| posted on 1/6/11 at 09:56 PM |
it looks like a seat belt spacer
JeffJeffers
| posted on 1/6/11 at 10:04 PM |
Height doesn't really matter, I guess about 10-15mm. Made from alloy or steel.
I need 6.
[Edited on 1/6/11 by JeffJeffers]
mcerd1
| posted on 2/6/11 at 07:16 AM |
so a seat belt spacer will me too big and most of the off the shelf generic top-hats I've seen are plastic....
so unless someone else knows where to get one you might need to get them made up on a lathe - try flak monkey
http://www.customworkshop.co.uk/
(normally I could do them for you but my lathes broke at the moment )
out of intrest what are they for ?
40inches
| posted on 2/6/11 at 07:25 AM |
Look like rod end reducing adapters? Could try McGills
scudderfish
| posted on 2/6/11 at 07:41 AM |
What are you going to use them for?
JeffJeffers
| posted on 2/6/11 at 10:20 AM |
I have made a radiator braket out of 12mm tube. I have used 6mm bolts to bolt it to the chassis.
So I thought it would just finish it off nicely.
JeffJeffers
| posted on 2/6/11 at 09:13 PM |
Got sorted thanks for everyones help.
flak monkey is going to make me some.
