ash_hammond
| posted on 8/3/12 at 01:23 PM |
WTD: Pinto Timing Cover Bolts and Washer
As the subject.
The 'special' bolts that screw into the engine that the timing cover bolts to.
Ash
[Edited on 8/3/12 by ash_hammond]
.: www.mac1motorsports.co.uk | www.m1moc.com :.
rash12
| posted on 8/3/12 at 01:25 PM |
what do you want ?
| posted on 8/3/12 at 01:26 PM |
I hope it's a MG KV6 engine...
It's Evolution Baby!
ash_hammond
Fat fingers pressed the enter key before i had finished.
quote: Originally posted by rash12
what do you want ?
jollygreengiant
| posted on 8/3/12 at 03:25 PM |
6mm bolt, a washer (large-ish if possible) and then the end off of an air-line coupling (female) cut to the right length (as a sleeve, I think you can
just get two, if you are VERY careful, out of one air-line end IIRC).
Edit bit
How do I know, I've dropped/lost one on a saturday/sunday when I've wanted to finish a rebuild/install and everywhere else is shut. In
those days I even used to keep the broken ends of the bayonet airline fittings. Oh and I would even replace the damaged/spit rubber grommets with
small wiring grommets.
[Edited on 8/3/12 by jollygreengiant]
Andy S
| posted on 8/3/12 at 07:19 PM |
If I say £10 for a pair posted - pretty sure there are only two - then someone is bound to come along with a free pair - however if they dont you can
always come back with a counter offer of sufficient value to make it worth my while digging through the "special" bolts box to find them.
I know they are there amongst the funny rocker cover washers and bolts etc.
Andrew
