Author: Subject: Wtd: lathe & tapping work
Benzine
posted on 31/3/12 at 04:34 PM Reply With Quote
Anyone with a big lathe looking for a few non-alcoholic beer tokens? or know where I can get it done locost? East midlands preferably
I'm trying to mate up an auto box to an engine. I need to use the torque converter from the auto box which will mean accurately centering the flex plate (from an autobox that originally mated up to the engine) and drilling and tapping the torque converter so the flex plate can bolt on. The stub on the torque converter that slots into the crank needs turning.
Flexplate held roughly in place. I could weld up the existing 3 holes on the flexplate or maybe 2 new holes drilled and tapped either side of it? Then the excess needs to be trimmed off.
Torque converter stub. It's 18mm then steps up to 19mm. I need it to be 18mm for the whole length.
FANX
daviep
posted on 31/3/12 at 07:17 PM Reply With Quote
My thoughts
1. Weld up existing holes on outside of flex plate
2. Bore two more holes on each leg for fastening to the torgue converter
3. Make a hub up which the flex plate could be bolted to and would locate on the spigot to centralise.
4. With flex plate centralised bore the mounting holes through into the torque converter, also bore 3x smaller dowel holes to maintain position after hub fremoved
5. Remove excess from outside of flex plate
6. Reduce spigot size
7. Fit dowels to converter
8. Assemble everything.
Questions:
What is the OD of the convertor?
What is the depth from the the flywheel face to the gearbox side?
Davie
clairetoo
posted on 31/3/12 at 07:23 PM Reply With Quote
That loos like something I could do.........
Its cuz I is blond , innit
Claire xx
Will weld for food......
MikeR
posted on 31/3/12 at 07:28 PM Reply With Quote
looks ideal for clare and her gap bed lathe.
daviep
posted on 31/3/12 at 07:36 PM Reply With Quote
What are you doing for a starter ring gear?
Davie
Benzine
posted on 31/3/12 at 08:19 PM Reply With Quote
Awesome, I'll send you a U2U now claire
Davie
Hi Davie, thanks for info in your first post. The flexplate is bolted onto the crank along with an auto flywheel:
