Author: Subject: OMEX 600 WIRING LOOM
zetec-phill
posted on 23/12/12 at 11:42 AM Reply With Quote
Im after a ready made omex 600 loom for a zetec blacktop, complete with all the plugs, if possible
jeffw
posted on 23/12/12 at 07:21 PM Reply With Quote
I guess ringing Omex isn't what you had in mind?
zetec-phill
posted on 24/12/12 at 05:22 AM Reply With Quote
you got that right
jeffw
posted on 24/12/12 at 07:56 AM Reply With Quote
I think you are in for a long wait then. Just in case here are the prices from Omex
OMEM1419 Road Spec Basic Loom (600 system) PVC tubing and harness tape, ready built harness for basic NA engines £174.00
OMEM1419A Road Spec Basic Loom with MAP (600 system) As above but with MAP connection for boosted engines £186.00
OMEM1519 Race Spec Basic Loom (600 system) Raychem sleeved, ready built harness for basic NA engines £294.00
OMEM1519A Race Spec Basic Loom with MAP(600 system) As above but with MAP connection for boosted engines £312.00
OMEM1520 Race Spec Full Loom (600 system) As above but with MAP connection and auxiliary connections £354.00
OMEM1502 Semi Assembled Wiring Loom (600 system) ECU connector with 3m trailing colour coded cables £60.00
OMEM1504 Auxiliary Wiring Pack for OMEM1502 (600 system) Add-on pack to OMEM1502 for auxiliary functions £12.00
I guess you would need the OMEM1419 if you want plugs as well at £174 or the OMEM1502 at £60 if you want to DIY with the plugs.
[Edited on 24/12/12 by jeffw]
zetec-phill
posted on 1/1/13 at 01:39 PM Reply With Quote
still in need of one
wylliezx9r
posted on 1/1/13 at 03:29 PM Reply With Quote
Your chances of getting the loom on its own 2nd hand are slim to none, the self assembly loom at £60 is reasonable you just need the connectors off the old engine loom and your done. Omex are really helpful if you run into any difficulty.
George Best
