Author: Subject: Plastic Cope Moulding Trim
Dick Axtell
posted on 22/5/13 at 12:08 PM Reply With Quote
Hopefully, there will be at least one LCB-er who has info on this stuff.
I need plastic edging trim, to cap the seating area side rails. Fitting width - 29mm, with suitably radiussed outer edge, so hockey-stick type extrusion section would be OK.
Have Googled various sites in UK, but nothing suitable found. Does anyone know of possible source?
[Edited on 22/5/13 by Dick Axtell]
deanspoors
posted on 22/5/13 at 12:22 PM Reply With Quote
Not this stuff?
Small black rubber car edge trim | eBay
[Edited on 22/5/13 by deanspoors]
skov
posted on 22/5/13 at 12:50 PM Reply With Quote
I think he's thinking more along the lines of this stuff, but in plastic:
http://www.clickmetal.co.uk/Angle-Types/Mouldings/Aluminium -Cope-Mouldings/p-16-8-16/
mark chandler
posted on 22/5/13 at 01:25 PM Reply With Quote
Baines, Tunbridge Wells will sort you out.
http://www.coh-baines.co.uk/
davidimurray
posted on 22/5/13 at 02:10 PM Reply With Quote
You can get various wooden mouldings from diy stores.i did the edge of my cockpit and tunnel with some profiled angle from wickes. Sanded back and then sprayed black for the curved shoulder bars I used wheel arch trim from cbs.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Dick Axtell
posted on 22/5/13 at 05:26 PM Reply With Quote
Thank you All, for your suggestions. Will check them out.
The Cope Moulding description seems to apply more specifically to what I need, rather than "edge trim".
posted on 22/5/13 at 05:40 PM Reply With Quote
I got some dome top in aluminium from B&Q, one length did both sides.
