Dooey99
| posted on 2/6/13 at 07:58 PM |
exhaust manifold help
can someone supply me or tell me where i can get a stainless exhaust manifold for my car (zetec engine) i want it to run through the side panel
ideally rather than through the bonnet but will consider either at the right price i would prefer a second hand one as im trying to keep the cost down
because i just keep spending and spending and as the goverment think £2.60 is an appropriate minimum wage for an apprentice and my boss is tight, im
struggling to keep up with the money.
[Edited on 2/6/13 by Dooey99]
Less weight more speed, more power more speed
If in doubt, give it a clout
Davey D
| posted on 2/6/13 at 08:03 PM |
What engine are you running?
Dooey99
| posted on 2/6/13 at 08:05 PM |
that is a very good question should of really mentioned that...
1800 zetec blacktop but it the same as all the zetec engines i believe
big_wasa
| posted on 2/6/13 at 08:11 PM |
Get your self a s/h St170 manifold and modify it. I will be starting one this week. Its got big equal length primary's and will come out of the
side panel.
Dooey99
| posted on 2/6/13 at 08:19 PM |
whats the best way to modify it?
big_wasa
| posted on 2/6/13 at 08:57 PM |
There is a guy on here that has done one but I cant find the pic's.
You need to cut the bottom of the exhaust where it turns under the engine and route it out of the side panel. There is one on ebay for £45 bin
[Edited on 2/6/13 by big_wasa]
macc man
| posted on 2/6/13 at 09:34 PM |
I made just such a manifold in stainless quite cheaply, If you buy a pre-cut manifold blank off ebay and find an exhaust manufacturer they will often
let you buy a selection of tube and bends. If you tack them together they will tig weld it for you.
It will save you loads.
snapper
| posted on 3/6/13 at 04:08 AM |
GBS do probably the cheapest pre made side exit
I eat to survive
I drink to forget
