Author: Subject: Wtd- 2 clevis pins and 2 R-clips to match
nitram38
posted on 6/1/09 at 01:56 PM Reply With Quote
I am after two clevis pins to fit a rover handbrake cable at the caliper end.
They need to be 6mm dia max (not 1/4" must be metric) and 15mm between the head and the clip hole.
I've tried all of my local shops and ebay but most carry imperial sizes.
Cheers Martin
posted on 6/1/09 at 02:01 PM Reply With Quote
how about a long 6 mm bolt, cut of the threaded part and drill small hole? if you want to get fancy, stick in drill press and file head to make it circular?
nitram38
posted on 6/1/09 at 02:03 PM Reply With Quote
I would prefer the correct clip but as a last resort that sounds like a good option.
stevebubs
posted on 6/1/09 at 02:16 PM Reply With Quote
close...
http://www.proboat.co.uk/item.asp?dep=2&prod_id=261&cat_id=32
posted on 6/1/09 at 02:21 PM Reply With Quote
http://www.tradetalk.com/Search.aspx?CategoryID=4154&SearchTerm=6+mm+clevis
21 mm long in stainless - saw and drill as before.
or
18 mm is shortest here:
http://marinestore.co.uk/Merchant2/merchant.mvc?Store_Code=mrst&Screen=PROD&Product_Code=PBBW-061806
nitram38
posted on 6/1/09 at 02:23 PM Reply With Quote
Originally posted by stevebubs
close...
Searched their site. No stockists near me
Mr Whippy
posted on 6/1/09 at 02:43 PM Reply With Quote
order on line like I do for my dingy
stevebubs
posted on 6/1/09 at 02:51 PM Reply With Quote
http://www.springfix.co.uk/
Close enough?
nitram38
posted on 6/1/09 at 05:54 PM Reply With Quote
Cheers Guys. I am at work tonight so I will give some of these a try tomorrow.
