Hornet
posted on 2/2/04 at 10:30 AM |
Rivnut Tool
Lookin to buy / rent / borrow a rivnut tool, anyone ???
| posted on 2/2/04 at 11:03 AM |
Hornet,
MK supply a rivnut tool with the Indy kit, which I think they make themselves. Might be worth a phone call as I can't see it being very
expensive.
HTH
Nick
Mk-Ninja
| posted on 2/2/04 at 11:21 AM |
£29-38 from MK including assorted rivnuts
I'm sure I've got one, just don't know where I've put it
Dick Axtell
| posted on 2/2/04 at 12:09 PM |
Hornet - R U offering your rivnut tool? If so, I'd be interested.
Spoke at length last year with nut insert supplier (Primary Fasteners). His advice re fitting rivnuts into steel - use the BIG tool, i.e. one with
arms like those bolt-cutters. Priced @ GBP80 + vat!!!
Hornet
| posted on 2/2/04 at 02:45 PM |
hi Dick
I am looking for a Rivnut tool not selling.. hence its in the wanted section
Cheers anyways
Mix
| posted on 2/2/04 at 05:35 PM |
If you only require to set a few nuts then it is easily done using a piece of appropriate sized threaded bar or a set screw, nuts and washers. If you
can't work it out for yourself I'll try to come up with a drawing / explanation.
Mick
Hornet
| posted on 6/2/04 at 08:08 AM |
Drawing would be nice.. I was never anygood with Blue Peter stuff
Mix
| posted on 6/2/04 at 09:26 AM |
Basic Rivnut 'Tool'
The left hand drawing shows a set screw, nut and washer assembled to a rivnut and inserted into a section of tube.
By holding the set screw head and turning the nut clockwise as viewed from above the rivnut will become set as in the right hand drawing. Remove the
nut washer and set screw and move on to the next rivnut.
I would advise doing a practise rivnut in a position where you can observe what is happening inside the tube, this will allow you to assess the amount
of 'draw up' required to set the rivnut without stripping the thread.
Hope this helps
Mick
