f1ngers
| posted on 16/3/09 at 10:59 AM |
Wtd: BEC Propshaft
I am looking for a 2 piece propshaft for a Stuart Taylor Locoblade with an overall length of 1445mm allowing for the angle to the centre bearing.
Approx. 500mm from Blade sprocket adapter flange to centre bearing and 945mm from centre bearing to Sierra diff flange
Perhaps you have recently upraded to a TRT prop and have the old one available.
Alternatively can anyone recommend a good locost supplier?
MK9R
| posted on 16/3/09 at 11:31 AM |
I have one but it comes with a quaife reverse box
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
skippad
| posted on 16/3/09 at 12:41 PM |
Ive got one out of me MK
I'll measure it later, see if it will fit
f1ngers
| posted on 16/3/09 at 04:42 PM |
Thanks MK9R but I don't 'need' reverse as I am waiting for my SVA date ahead of IVA.
Thanks skippad. My measurements are approximate as I don't know where the centre bearing will mount but I assume it has a slider in one end
which will provide some adjustment. I believe the MK and STM chassis are pretty close.
skippad
| posted on 16/3/09 at 10:11 PM |
just measured my propshaft...
Its very close to your dimensions...just might fit.
Overall 1440mm
short piece 530mm
longer piece 910mm
let me know
f1ngers
| posted on 17/3/09 at 06:34 PM |
skippad - you have U2U
skippad
| posted on 17/3/09 at 11:14 PM |
You to have a u2u
