Author: Subject: fuel tank sender wanted
snippy
posted on 29/3/09 at 11:45 PM Reply With Quote
I need a fuel tank sender for my mates Westfield. He has VDO instruments/gauges fitted so I`d imagine its a VDO sender he has fitted in the tank. Has anyone got one for sale or know of an outlet for them? The car is a Westfield SE built in 1992. Thanks.
Nick
:{THC}:YosamiteSam
posted on 2/4/09 at 01:09 AM Reply With Quote
i have a VDO sender you can have - it needs a gasket. it was mounted using an internal ring in the tank - iv used that on the new guage i swapped it with (racetech) so if you can mount it without the ring - or make one and get a gasket you can take it from for say - tenner? im going to stoneleigh show if you want i can bring it there?
the sender float is reversible - top tank mounted - uses 5 bolts if i remember right - 2 connections - earth and signal to guage
