Charlie_Zetec
posted on 2/4/09 at 02:14 PM |
WANTED - Zetec exhaust manifold!
Hi people, I'm in need of an exhaust manifold for my 1800 Zetec based GTS. I have a rear box, but nothing from the block itself.
Not fussed whether it's a 4-1 or 4-2-1 or system, as my bodywork has no cut out for it as yet; I'll have to do that myself as and when.
If item is nearby to Essex I can prob come collect it or meet you somewhere, but if not I can arrange courrier collection through the logistics
department at work.
Many thanks!
mikeb
| posted on 2/4/09 at 02:55 PM |
I have one you can have to get you up and running on a budget.
Its a 4 into 1 collector down the outside (fairly standard). Looks nice for mildsteel manifold
Its Mild steel, currently it doesnt have a manifold plate attached as I was going to extend the primaries so it suited my roadster chassis. In other
words you need to weld it to a manifold plate (£20 from shortrack, I have one but its not the best). I'll even throw in some tube to extend the
primaries.
£45 and you arrange courier
I had pictures of it up a while back, so pictures should eb on the forum somewhere.
If your after a spanky stainless one then this obviously isn't for you, but it is locost!
Mike
Danozeman
| posted on 2/4/09 at 03:07 PM |
Mine cam from fisher sportcars from a Fury, clears the chassis just nice.
Depends how much money you want to spend,.
Dan
DavidW
| posted on 2/4/09 at 09:18 PM |
I bought one from great british sprtscars (robin hood) for £150.
It seems pretty good for the money although I've just sent it back to them so they can make me one with 25mm longer pipes at the manifold to
clear the top rail on my MK chassis.
Very impressed with the GBS service!
