Author: Subject: Metal convoluted tubing type stuff.
Staple balls
posted on 4/4/09 at 02:03 AM Reply With Quote
I'm after some of the tubing like is on these, any idea what it is, and where I'd get it?
James
posted on 4/4/09 at 02:32 AM Reply With Quote
Not in anyway full details but might be useful.
In one of the offices at work all the desk power socket blocks were supplied by wire covered in this stuff.
It was bigger than the stuff in that photo (at about 15mm) but I'm sure you can get different sizes.
So I'm guessing an electrical supplies/wholesaler place could help you.
HTH,
James
Staple balls
posted on 4/4/09 at 02:44 AM Reply With Quote
ah-ha. got it.
Took a while, but found it here, not even remotely cheap, but it looks good.
robinj66
posted on 4/4/09 at 06:40 AM Reply With Quote
you could try shower hose
big_wasa
posted on 4/4/09 at 07:16 AM Reply With Quote
Yep shower hose. Cheap and comes with a rubber coating.
Staple balls
posted on 4/4/09 at 07:18 AM Reply With Quote
and is about 3 times the diameter I want
omega 24 v6
posted on 4/4/09 at 08:27 AM Reply With Quote
Here's what the stuff is called. Available in many diameters in steel and stainless steel. Any big electrical wholesalers will be able to get it for you BUT probabaly you'd need to take a whole roll/coil.
At least it lets you know what to search for.
the proper stuff
Danozeman
posted on 4/4/09 at 08:58 AM Reply With Quote
All our alarm door sensors at work are coverd with that stuff.
Dan
NS Dev
posted on 4/4/09 at 09:30 AM Reply With Quote
yep, electrical conduit, prob known as "stainless anaconda" at your local sparky supplies (which is probably CEF in leicester) but yep I doubt they will split a roll, and we don't have any at work as small as that
mad4x4
posted on 4/4/09 at 09:34 AM Reply With Quote
What about getting some of the black plastic and spraying it silver and lacquer it. Low cost solution.
Scot's do it better in Kilts.
rgrs
posted on 4/4/09 at 11:06 AM Reply With Quote
What diameter (o/d and i/d) do you want, as mentioned above heavy duty alarm contacts are fitted with this but maximum length is about 350mm. Ill find some and measure for you.
Roger
907
posted on 4/4/09 at 01:34 PM Reply With Quote
I've got some 5mm i/d and some 8mm i/d
Paul G
Staple balls
posted on 4/4/09 at 02:23 PM Reply With Quote
8mm ID is what I'm after, probably after two 12" lengths-ish
obviously, I'll pay well
907
posted on 4/4/09 at 06:28 PM Reply With Quote
How about a pint of beer (£3) + the postage?
U2U me your address if that's OK
Paul G
Staple balls
posted on 4/4/09 at 06:54 PM Reply With Quote
Done.
cheers!
