theconrodkid
| posted on 11/4/09 at 12:21 PM |
big f/o washers
i need 4 washers,not any old washers but washers with a 48mm id hole,anything 68 + for the od and as thin as possible (aprox 1mm) but they must be
made of unobtanium or similar as i dont want them to be able to bend....is this a request too far even for the LCB mahoosive?
[Edited on 11/4/09 by theconrodkid]
who cares who wins
pass the pork pies
snapper
| posted on 11/4/09 at 12:24 PM |
You need someone to turn up some thick sheet
I eat to survive
I drink to forget
redscamp
| posted on 11/4/09 at 12:26 PM |
get the hole saws out
theconrodkid
| posted on 11/4/09 at 12:30 PM |
just edited the post to say the ideal thickness is about 1mm
who cares who wins
pass the pork pies
tomprescott
| posted on 11/4/09 at 01:21 PM |
Roll out some steel to 1mm and cut/drill. Unlikely to find ones that are strong and that thin. That said, have a look on your local trading estate for
a farm engineering shop - if its anything like the one near me they should have a very very wide range of nuts, bolts and washers. HTH
| posted on 11/4/09 at 01:35 PM |
I'm sure someone on here could machine something for you in stainless steel. Unfortunately not me though............ but if I could, I
would...........
Phil
omega 24 v6
| posted on 11/4/09 at 02:51 PM |
I could go and measure some later but this must be close to the size of an english axle lsd diff shim.
Just measured one it's 50mm bore and 76mm OD
Available from burton etc
like this
[Edited on 11/4/09 by omega 24 v6]
MakeEverything
| posted on 11/4/09 at 03:38 PM |
What is the application? Someone here might have a suitable alternative or may have overcome by other means.
Kindest Regards,
Richard.
theconrodkid
| posted on 11/4/09 at 04:52 PM |
in a nutshell,i have a 48dcoe manifold and gsxr throttle bods,fitter the webber spacer with O rings ,the bods are a nice fit inside
trouble is the spacers are nylon and bend when they are tightened up and cause an air leak,need something stiff to keep them flat
omega,those spacers would be ideal but they need to be really stiff
looks like i,m sorted now,cheers for your replies peeps
who cares who wins
pass the pork pies
austin man
| posted on 11/4/09 at 09:45 PM |
your not meant to tighten them up fully, they are designed to allow the carb to move to prevent the fuel frothing in the carb, they have special
spring washers which need to be set up using feeler gauges. I know cos I did the same thing and bust mine check ebay and look for fastroadcars he sell
the stuff I think the washers are called Thakeray washers. Other than that remove the o ringsd and seal the pacer using a petrol friendly sealant not
sure if silicone will do it.
theconrodkid
| posted on 12/4/09 at 06:49 AM |
Austin man,you reading my mind?,thats who i got the spacers from and i removed the O ring and siliconed them to the manifold,they are still a bit
floppy tho hence the need for washers.
the bods slide inside the spacers not bolt on,that would be to easy
who cares who wins
pass the pork pies
