Author: Subject: Can someone machine a part for me!!!
prawnabie
posted on 12/4/09 at 01:38 PM Reply With Quote
Hi
Basically I have bought a steering wheel with no fixing holes in it that I have drilled and attached my snap off boss to.
Unfortunatley the snap off boss is smaller than the boss the is already on my column so i cannot bolt the two together.
Can somone in the midlands machine me a round piece of ally with a diameter of 117mm and a thickess of about 4mm or slighty thicker with do. I can drill my own holes in it for the pcd's of the two bosses, but I havent the machinery or the materials to make the piece.
I can pay cash before or on collection!
Shaun
[Edited on 12/4/09 by prawnabie]
posted on 12/4/09 at 02:23 PM Reply With Quote
if I had themachinery I would do it but do not dispair.
sounds like you need an adapter so you can drill two circles of holes for the differennt pcd.
I have something similar on mine made from 2 mm (? approx) mild steel.
It doesn;t need to be ultra price; you can make this yourself i you have a drill press. drill holes in circle with progressibely larger bit until the holes choin up or you file them so they join up = chain drilling.
same on outer.
then file to shape.
takes a bit of time but doable without specialist machinery.
see my post about trigger wheel - contact the bloke and I am sure he can laser cut you a disc for about a tenner.
prawnabie
posted on 12/4/09 at 02:47 PM Reply With Quote
Thanks lads, will have a crack tomorrow!
madrallysport
posted on 13/4/09 at 01:30 PM Reply With Quote
u2u sent
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
