Miks15
| posted on 17/4/09 at 09:31 AM |
Couple bits machining WTD
Im after a couple of bits machining. The bits in question are for my suspension strut inserts. Mine are a bigger diameter to sierra inserts therefore
i cant just use an off the shelf item.
If someone can help me out ill get drawings to them striaght away.
Cash waiting
Mikkel
Phil.J
| posted on 17/4/09 at 10:01 AM |
U2U sent
Phil
Got any pics? If they will fit in a 9" lathe i may be able to help.
Miks15
| posted on 17/4/09 at 10:28 AM |
It is not quite to scale as all ive done is taken the sierra adaptor drawing and changed 2 dimensions so the overall diameter is larger. But all the
dimensions are there.
Mikkel
| posted on 17/4/09 at 11:04 AM |
So you want that 52mm taking down? How much by my good man?
matt_claydon
| posted on 17/4/09 at 11:16 AM |
I think he wants the whole thing machined from scratch as it's bigger than the sierra ones.
You'll want to do the taper with the appropriate reamer, you're very unlikely to get the angle accurate enough for the ball joint to
locate propery by trying to do that on a lathe.
[Edited on 17/4/09 by matt_claydon]
| posted on 17/4/09 at 11:20 AM |
In that case why not just buy some that fit the Sierra uprights?
hellbent345
| posted on 17/4/09 at 11:59 AM |
that depends on whether the lathe in question is CNC or manual, i could easily do that angle on my lathe but thats because its CNC - and coozer its
because he needs them similar but slightly larger than standard sierra ones on the diameter that fits into the strut.
[Edited on 17/4/09 by hellbent345]
| posted on 17/4/09 at 12:10 PM |
My lathe is manual, there was no such thing as cnc in the 1800's when I started at the pit
hellbent345
| posted on 17/4/09 at 12:13 PM |
lol
