Author: Subject: Wanted: DCOE inlet manifold for 1800 CVH
Keith Weiland
posted on 4/5/09 at 06:47 PM Reply With Quote
I am in need of a DCOE inlet manifold for a 1800 CVH. Please PM me with price if you have one. Thanks.
[Edited on 4/5/2009 by Keith Weiland]
whitestu
posted on 4/5/09 at 07:03 PM Reply With Quote
I could be wrong, but don't think you can get one off the shelf.
Stu
[Edited on 4/5/09 by whitestu]
yellow melos
posted on 4/5/09 at 07:04 PM Reply With Quote
could try burtons
www.burtonpower.co.uk
are the inlet the same as the 1.6 cvh ???
Gazeddy
posted on 4/5/09 at 07:16 PM Reply With Quote
nope 1800 has the coolant come out of the head into the manifold. dont think there is one you can get mate
Keith Weiland
posted on 4/5/09 at 07:28 PM Reply With Quote
Bah, didn't know that thought they were the same.
Keith Weiland
posted on 4/5/09 at 07:48 PM Reply With Quote
Ok, assuming I can't get one off the shelf, what would the effect be if I made one up that blocked off the water channels or better yet could I put a 2mm plate between the block and a 1600 inlet manifold that blocked off the water channels?
AdrianH
posted on 4/5/09 at 07:50 PM Reply With Quote
I know someone who has fitted bike carbs on the CVH so something is out there.
The ports are the same just have to deal with the waterways, in the middle 2 and 3 ports on the 1.6 and at end of port 4 on the 1.8.
Let me search for a bit.
Adrian
It was wrigglypig another Haynes builder, So as you posted above fit a plate between a 1.6 inlet manifold and the 1.8 Block
[Edited on 4-5-09 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
Keith Weiland
posted on 4/5/09 at 07:57 PM Reply With Quote
So you think it would work? In that case I am still looking for a CVH DCOE manifold if anyone has one.
Gazeddy
posted on 4/5/09 at 07:59 PM Reply With Quote
the rwd and fwd heads are different but from what i can gather interchangeable so it may be worthwhile fitting a fwd head which puts coolant out on what would be the back of the head
AdrianH
posted on 4/5/09 at 08:08 PM Reply With Quote
Have a look at wrigglypig photo archive, bear in mind that several other things will have to change when doing the conversion from what I have been able to understand.
You will loose the main waterway that normally goes through the inlet manifold. Once this is blocked off you will have to remove one of the core plugs on the back of the engine and fabricate a water outlet to go to the radiator and house the thermostat.
I also think the DCOE carbs will foul the fuel pump, so this will have to be removed, the hole blocked off and use an electric pump instead. Plates are sold on ebay for about £3.50 for that.
Contact Mark I think is the best bet, in fact go for carbs as a cheaper option then the DCOE. If it makes a big difference on the 1.8 I am not sure, this is not a gas flow head. See pumaracing web site for general information.
http://www.pumaracing.co.uk/CVH.htm
Hope it all helps
Adrian
Keith Weiland
posted on 4/5/09 at 08:19 PM Reply With Quote
Its really a cost cutting measure for me as I already have the carbs and the 1800cvh but dont want to put a hole in my bonnet so need to replace the pierburg with something else. I suppose I could sell the twin 40's and buy some bike carbs then copy what wrigglypig has done. Having looked at his build diary I didn't notice how he has dealt with the water outlet. I will have to have a closer look.
AdrianH
posted on 4/5/09 at 08:41 PM Reply With Quote
If you look in his archive
DSCF0712.JPG shows how the plate blocks off the water way.
DSCF0716.JPG shows the back on the engine and the right hand core plug is where you take the water from. It has two tapped holes to mount some form of thermostat housing.
Adrian
Keith Weiland
posted on 4/5/09 at 08:50 PM Reply With Quote
Cheers Adrian
