tegwin
| posted on 14/5/09 at 05:00 PM |
WTD: Oil catch tank
Anyone got an oil catch tank with two inlets they want to sell? Dont care if its a bit battered and in need of re-painting
What have you got?
[Edited on 14/5/09 by tegwin]
www.verticalhorizonsmedia.tv
mark chandler
| posted on 14/5/09 at 05:45 PM |
Stainless biscuit tin Morrison’s £2.99, bore a big hole in the lid for the feed in, grommet and push the pipe through then a hose coupling or similar
for the outlet and put a cheap filter on top from Ebay, of if really tight drill a selection of small holes in a really neat patten.
adithorp
| posted on 14/5/09 at 06:05 PM |
I modified an ally drinks bottle. Drilled the lid and bonded 2 tubes in.
Aldi have them in at the moment. About £5.
adrian
http://jpsc.org.uk/forum/
ernie
| posted on 15/5/09 at 04:48 PM |
or a posh stainless loo brush holder from bhs £12
40inches
| posted on 15/5/09 at 07:49 PM |
Got an ally one you can have 16cm high x 12cm wide x 14cm deep It's got 2 13mm connectors at top one end, 2 10mm connectors on other end and a
15mm drain near the bottom on one side. Well manky but should clean up.
Forgot to say, just want postage for it.
[Edited on 15-5-09 by 40inches]
jacko
| posted on 16/5/09 at 06:13 PM |
I used a oil spray gun can remove the gun bit and fit a small filter on
the top is removable to clean the old crap oil
I also drilled the side and fitted a air line end though the side to fit a pipe to it
its a aluminium one so nice and shiny
[Edited on 17/5/09 by jacko]
  Nice new catch tank
