Danozeman
| posted on 15/5/09 at 05:06 PM |
Zetec arp rod bolts
Wheres the cheapest place to buy arp con rod bolts for a zetec??
Or has anyone got any going spare.
Dan
philw
| posted on 15/5/09 at 05:11 PM |
try this
link
Must try harder
Danozeman
| posted on 15/5/09 at 06:02 PM |
Cant remember if they were 8 or 9mm now when i built the engine.
Dan
philw
| posted on 15/5/09 at 06:10 PM |
Check the part number on an ARP suppliers website
Must try harder
Danozeman
| posted on 15/5/09 at 07:57 PM |
Looks like 2 litres have 9mm and 1.8s have 8. So im assuming mine are 8mm.
Has anyone got ford micro cat to check the standard part number to see if they size comes up??
The standard ones i fitted are 1053066.
Dan
Dusty
| posted on 15/5/09 at 08:10 PM |
I believe all sivertops use 8mm all blacktops use 9mm. Doesn't go by the size of the engine.
snapper
| posted on 16/5/09 at 06:55 AM |
If you sre going to rebuild the engine, do a strip down measure the old bolts, order new, check new bolts (some ARP fixings need a little
machining/shortening to fit)
I eat to survive
I drink to forget
Danozeman
| posted on 16/5/09 at 08:22 AM |
Im not rebuilding it. I have a scholar shortened sump to fit so though id swap the bolts while the sumps off. I dont wanna take the sump off and
have to wait for the bolts as i like to keep it useable for when the suns out
Dan
