philw
| posted on 28/5/09 at 01:37 PM |
XE Block Wanted
I need a decent XE block standard bore if anybody has has one? preferably with an HG code.
Must try harder
blakep82
| posted on 28/5/09 at 01:42 PM |
does it have to be from an actual xe? do you need it for something to do with the engine numbers etc? coz the ecotec is exactly the same isn't
it?
________________________
liam.mccaffrey
| posted on 28/5/09 at 02:12 PM |
I forgot to check mine phil will look tonight, still want the gbox?
Build Blog
Build Photo Album
philw
| posted on 28/5/09 at 02:40 PM |
it?
No it doesn't have to be from an XE, it can be from an XEV or an XER or from a Daewoo, i dont really care, all my blocks need a rebore which
means new pistons and as i'm skint i can't afford it, the pocketed pistons i have acquired are standard bore, i will look out for a set
of oversize pistons then when i get a job i can build a spare engine
Must try harder
