Daddylonglegs
| posted on 1/6/09 at 10:40 AM |
Pinto Ignition
Hi all.
As it seems I am the proud owner of a 1.6 E-Max Pinto , I am now in need of an ignition module for it. I have the hall-effect dizzy (I hope!), and
the red cap (so I assume it's the Bosch?)
Anyone got any ideas please?
mcerd1
| posted on 1/6/09 at 10:56 AM |
you could just use a points type dizzy if you can find one
but if your thinking about upgrading later anyway - why not use megajolt ?
then you just need the bottom half of the dizzy to drive the oil pump and you'll have a fully programable ignition system that you can keep when
you upgrade
and you'll probably get better mpg as well
if you get the donor bits from a scrapyard (or maybe someone on here) you should be able to get the whole system for £150
btw - what carb have you got at the moment ?
Daddylonglegs
| posted on 1/6/09 at 11:42 AM |
Not sure what carbs I have at the moment, I've got the one that came with the engine, and another from some guy on here (called mcerd1 or
something  )
I don't mind going to points, but I really don't want to throw too much more money at this engine as I want to save up and buy somoething
a little more 'enjoyable'.
mcerd1
| posted on 1/6/09 at 11:59 AM |
quote: Originally posted by Daddylonglegs
I've got the one that came with the engine, and another from some guy on here (called mcerd1 or something  )
 thats off a 2.0 pinto from early sierra
(sorry thats all I know, it was on an engine that was removed 15+ years ago)
I guess you could use it on the 1.6 if you can get it re-jetted
the reson I'm suggesting megajolt is it will work on your engine now, and you can swap it strait onto a 'more enjoyable' engine
later
it'll work just as well on a 2.0 pinto and its exactly what you need to run a zetec/ redtop on carbs (and most other engines too)
have a read at this site: linky
-Robert
ps - I got my megajolt from Paulf on this site
[Edited on 1/6/09 by mcerd1]
