cd.thomson
| posted on 1/6/09 at 11:21 AM |
WTD:sierra prop bolts + box oil
Hi everybody,
I need the bolts to connect my propshaft into the car, its a 3.62 lsd and I'm not sure if I need bolts with nuts. Does anybody have any new?
Also does anybody have any gearbox oil left over for a type 9? preferably fully synth, but I'll take some 75W90 part synth if thats whats going
Craig
mcerd1
| posted on 1/6/09 at 11:32 AM |
the bolts are a fine pitch M10x1.0 (or maybe M12, I'd need to go and find a set to measure)
also they are grade 10.9
but if you've got a Dax prop I think it comes with new bolts (if you can find them)
I'll dig some out later and measure them (I might have a spare set to send you....)
[Edited on 1/6/09 by mcerd1]
cd.thomson
| posted on 1/6/09 at 11:37 AM |
I bought by prop second hand from a fellow dax builder, Dave (creamytash) so I don't think I have the prop bolts.
If you do have a spare would you be able to send me a U2U - failing that the sizes would be great too
Craig
mcerd1
| posted on 1/6/09 at 11:52 AM |
I'll have a look later on....
blakep82
| posted on 1/6/09 at 01:14 PM |
they are M10 on my atlas, which i think is the same as the sierra diff
________________________
mcerd1
| posted on 8/6/09 at 07:31 PM |
found the prop eventualy...... linky
the bolts that are with it are:
M10x1.0,
grade 12.9,
socket cap heads (allan key heads)
25mm long,
fully threaded
and they have some spring washers with them
[Edited on 8/6/09 by mcerd1]
