big_wasa
| posted on 10/6/09 at 07:35 PM |
wtd 1997 Mondeo wiring dia pls
I am after a good Engine managment / immobiliser wiring diagram for a 1997> Ford Mondeo 2.0 petrol zetec.
I have two haynes manuals but both show early pre pats cars.
Would the Ford Tis show this ? they sell for a few quid on ebay but dont want to waste cash if they just show part numbers.
Thanks as allways for any help.
redscamp
| posted on 10/6/09 at 08:33 PM |
the proper ford wiring manual is the size of a phone book
and still does not cover the pasive anti theft system
below is as far as i got so far
NO GUARANTEE OF ANYTHING BELOW
ECU OWLS
1 black/blue
2 black/orange
8 black/blue -> yellow/green PATS
9 black/blue optional
10 black/orange -> black/blue
13 white/blue data link conector DLC
14 violet/orange front window heater time relay
15 blue data link conector DLC
16 grey data link conector DLC
17 black/white optional not used high speed engine cooling fan relay A/C
19 green/orange -> black/white PATS
20 black/blue injector 3
21 white/red crankshaft postion sensor
22 brown/red crankshaft postion sensor
24 black/yellow
25 black/red
26 brown/blue ignition coil (2 cylinders)
27 black/yellow starter relay
29 black/blue -> white/black
30 white/black octane adjust plug
31 white power steering pressure switch
32 white
33 white
34 white
35 white
36 brown/blue mass air flow MAF sensor
37 green/yellow -> white/red
38 white/green engine coolant temperature ECT sensor
39 white/violet air charge trmperature ACT
40 violet/black optional fuel pump relay monitor
41 violet/blue A/C dual pressure switch
42 black/red -> black/blue alarm on LED in clock
43 white trip computer module
45 black/blue
47 black/green vaccuum regulator solenoid valve EVR
48 white/black tachometer
49 white/black
50 white/black
51 black/yellow
52 brown/green ignition coil (2 cylinders)
53 white/green PATS
54 black/blue -> black/white
55 orange/yellow fuse 11 3amp
56 black/orange optional
57 yellow/violet -> yellow/black -> green/yellow
58 white/violet vehicle speed sensor VVS
59 white/violet
60 white pre-catalyst heated oxygen sensor
61 white
62 white
63 white
64 white/green white clutch pedal switch
65 white/blue exhaust pressure transducer
66 white/blue
67 black/orange optional canister purge solenoid valve
68 black/blue optional engine cooling fan relay
69 black/yellow A/C wide open throttle relay WOT
70 black/blue black/white injector 1
71 green/yellow optional fuse 9 20amp pcm module relay
72 green/yellow optional
73 black/green black/yellow optional
74 black/blue
75 black/blue black/white
76 brown brown/white camshaft postion sensor
77 black/yellow
78 brown/yellow optional
79 white/red white/black
80 black/blue black/white fuel pump relay
81 black/red
82 black/red
83 black/yellow idle speed control valve
84 white/violet
85 white/violet camshaft postion sensor
86 black/blue
87 white/red optional
88 white/blue mass air flow MAF sensor
89 white throttle position sensor TPS
90 yellow common throttle position sensor TPS & exhaust pressure transducer
91 brown
92 violet
93 black/blue black/green optional
94 black/blue black/red optional
95 black/orange injector 4
96 black/yellow injector 2
97 green/yellow optional fuse 9 20amp pcm module relay
98 black/blue optional air management valve solenoid
99 black/red black/blue
100 black/orange
101 black/yellow
102 black/orange
103 black/yellow
104 black/yellow
engine plug C30001
1
2
3 black/green pin 1 c102
4
5 white/violet pin 10 c102
6 black/green splice to black blue pin 6 c140
7
8
9
10
11
12 green/black front window heater relay 12 green C102
13
14
15
16
17
18
19
20
21 violet/orange front window heater relay
22 white/red pin4 c102
23
24
25
26 white/blue pin 9 grey plug
27
28
29 black/yellow pin6 c102
30
31
32
33
34
35 black/yellow a/c wot
36
37violet/blue a/c wot pin 4 (1black/blue 2 violet 3black/blue)
38
39
40
41 black/yellow pin 15 c102
42
data link connector DLC C3000
2 grey/violet 8green 16 engine plug SCP+
4 black ground chassis ground
5 black/orange 9 engine plug black/green splice signal ground
7 white/blue 38 engine plug K-Line ISO 9141
10 blue/orange 2green 17 engine plug SCP-
13 white/blue white 6 grey 27 engine plug white/red module programming signal (petrol engines)
16 orange battery power
green plug ign barrel
1 yellow/green pin 13 C141 blue socket
2 black pin 7 C140 green socket and pin 12 C141 blue socket and pin 6 green C102 black/white)
3 grey/orange pin 12 C140 green socket
4 white/green pin 5 C140 green socket
speedo
long C808a
n/c
black/orange 31S-PF28
black/red 16pin IDE instrument interface module C440 91S-PF29
black/green pin 15 C141 31S-CF45
black/green air bag light 91S-MA14
white/red pin 4 C102 fuel gauge 8-GD7
n/c
white/black pin 11 C62 tachometer 48 pcm 8-GB10
violet 14-WC434
green/black pin 12 C102 battery warning light 15S-BA9
black/yellow 31S-DA1
violet/white pin 14 C141 main beam 14S-LE11
black/orange ground 91-WC43
orange/green RH direction indicator 29S-LG22
orange/black LH direction indicator 29S-LG15
white/red illumination 63S-LA31
speedo
short C808b
black/green pin 1 C102 oil pressure light 31S-WD9
black/red pin 7 C102 abs light 31S-CF28
black/yellow pin 10 C62 brake fuid hand brake 31S-WB6
black/yellow not used seat belt light? 91-GA6
white/blue pin 10 C102 speedometer 8-GB8
white/red pin 8 C143 8-GA7
black/orange ground????? 91S-PE15
violet/orange pin 8 C102 rear fog lights 14-LD13
violet/blue pin 10 C143 front fog lights 14S-LD7
green C102
1 black/green ??? black/green pin3 c30001
2 white/black
3 brown/yellow
4 white/red white/red pin22 c30001
6 black/white pin29 c30001
7 black/red black/red to dioed black/yellow pin10 grey
8 black/orange
9 black/blue black/blue engine fuse/relay box
10 white/blue white/violet pin5 c30001
11 green/black violet/yellow to violet/white to 2pin plugs
12 white/black green/black
13 white/black 2pin plug yellow/black
15 black/yellow pin41 c30001
16 blue blue pin 5 head light
green C140
1 grey/white
2 blue
4 white
5 white/green pats
7 black/blue slice to pin 6 c30001 pats
9 grey engine fuse/relay box
10 black ground splice
12 grey/orange pats
13 white/black
14 red engine fuse/relay box
blue C141
3 white/green
4 white/black
5 black/yellow
6 violet/yellow
11 black/red
12 black pats
13 yellow/green ??? pats
14 violet/white
mass air flow sensor (MAF) C9893
1 white/blue white/black
2 brown/blue brown/yellow
3 black/orange black/red
5 green/red violet/orange
fuel heater c1987
1 black
2 violet
blocking diode c1974
black/yellow
black/red
throttle position sensor TPS c1892
yellow
white
brown
camshaft postion sensor C1893
white/violet
brown/white
brown/red white/red
white/red brown/red
big_wasa
| posted on 10/6/09 at 08:39 PM |
Top man ive started to shell out the loom, two actually a manual and an auto but wanted to check it against something.
