Author: Subject: Wanted: Sierra Diff
ashg
posted on 2/7/09 at 07:55 AM Reply With Quote
Wanted: Sierra Diff
Hi all im on the hunt for a sierra diff mine was stolen :-(
my driveshafts are the push in type if that makes any difference?
Ash
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
bimbleuk
posted on 2/7/09 at 08:10 AM Reply With Quote
Hi
What ratio are you after? Also with push in shafts there were two sizes but the smaller size only appeared briefly in the earliest Sierras. I don't have the measurements to hand but I'm sure someone will post them.
richardh
posted on 2/7/09 at 08:13 AM Reply With Quote
not good that Ash!
i'll ask around too
Time for a change!
wilkingj
posted on 2/7/09 at 08:14 AM Reply With Quote
I have a push in shaft Diff, complete with shafts. 3.9 ratio
I have the bearing carriers as well. The drums and back plates are not that good. However, for about £15 (for the coversion plates) you could convert to discs, which IMHO would be worth it!
Best Regards
Geoff
http://www.v8viento.co.uk
ashg
posted on 2/7/09 at 08:36 AM Reply With Quote
Geoff i will keep you in mind cambridge is a bit of a drive. if nobody closer has anything then i will be in touch.
as for the ratio. the diff i had come off a 1.6 g plate pinto sierra. but to be honest any ratio is better than no diff. (is it gonna make a big difference on a 1.6?)
[Edited on 2/7/09 by ashg]
ashg
posted on 2/7/09 at 10:10 AM Reply With Quote
geoff you have u2u
gavin174
posted on 2/7/09 at 11:08 AM Reply With Quote
i have a spare diff what diameter are the shafts you have.. and waht ratio you looking for...
will check tonight for you if your interested
ashg
posted on 2/7/09 at 11:17 AM Reply With Quote
ratio isnt that important to be honest. i will pop out and measure the ends that push into the diff
ashg
posted on 2/7/09 at 11:39 AM Reply With Quote
the diameter of the shaft that pushes into the diff is 28mm thats measuring the unsplined bit.
gavin174
posted on 2/7/09 at 01:31 PM Reply With Quote
will try and get in the shed tonight and let you know...
if not im off work tommorrow so will check then
ashg
posted on 3/7/09 at 12:23 AM Reply With Quote
cheers for all the help guys Geoff come to the rescue. i drove up to cambridge this afternoon and collected.
cheers geoff your a star. was nice to see your car too.
