Ben_Copeland
| posted on 2/8/09 at 09:13 AM |
WTD: Broken Fiesta Radiator Fan Switch
Has anyone got a broken fiesta fan switch?
Just want something to plug the hole, seems a bit silly buying a brand new one.
The switch that switches on the fan, temperature switch. Screws into the radiator.
[Edited on 2/8/09 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
mookaloid
| posted on 2/8/09 at 09:34 AM |
perhaps someone with a lathe can turn one up out of brass for you?
Ben_Copeland
| posted on 2/8/09 at 09:52 AM |
Possible, but when they only cost about £7 off ebay, i'm not sure its really worth the effort.
Nice idea tho
Ben
Roadster
hillbillyracer
| posted on 2/8/09 at 10:25 AM |
It'll be a common enough thread used on tons of stuff, if you've got old engines etc lying about have a look over them & something
might be the right thing!
Ben_Copeland
| posted on 2/8/09 at 10:35 AM |
Looks like that ...
Ben
Roadster
hillbillyracer
| posted on 2/8/09 at 11:13 AM |
I could see that being a 22mm thread like a hydraulic fitting, I know the drain plug from the 4wd dropbox on a FIAT tractor would fit if it is!
I'm guessing you're clean out of FIAT tractor drain bungs though?
Ben_Copeland
| posted on 2/8/09 at 11:23 AM |
Yes, clean out till next year
It also fits in my polo rad.
The annoying thing is, i had 2 broken ones a while ago but i threw them away
Ben
Roadster
| posted on 2/8/09 at 11:41 AM |
Some of the older Range Rovers had a plastic bung in the top of the rad which IIRC would do the trick
Ben_Copeland
| posted on 2/8/09 at 12:02 PM |
Like that? Hope its the right thread.
Ben
Roadster
| posted on 2/8/09 at 12:07 PM |
Looks like the part, I'm fairly sure it is the same but do check the thread
