Author: Subject: PUSH IN DRIVESHAFTS WANTED
Gary 7
posted on 20/8/09 at 09:25 PM Reply With Quote
Anyone have a pair of 27mm diameter push in shafts with 25 splines they want to sell.I want use an lsd with drums and want to fit lobro joints on the diff end.I found a pair of 27mm shafts from a 1.8 cvh but when i cut open the joint cover and removed tripode they were 32 spline and the smaller shafts i have are 22 spline.
Reading threads on here they seem to be fitted to 2 litre models.
madrallysport
posted on 21/8/09 at 07:23 AM Reply With Quote
I might have a set, i'll check after work for you
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
