Author: Subject: wtd 6mm diameter cable nipple
blakep82
posted on 24/8/09 at 03:59 PM Reply With Quote
like these
http://www.cbsonline.co.uk/ekmps/shops/carbulder/images/slnip.png
but 6mm diameter. cbs only have them in 9mm form
anyone got any spare?
________________________
r1_pete
posted on 24/8/09 at 04:05 PM Reply With Quote
Vehicle wiring products list quarter inch ones??
blakep82
posted on 24/8/09 at 04:08 PM Reply With Quote
1/4" works out to 6mm doesn't it? yeah that should be the one. its only for a throttle cable. the nipple is to go on the carb end of the zx9r carbs.
anyone got a spare one or two?
posted on 24/8/09 at 06:01 PM Reply With Quote
Have you look at the chocolate block connectors at B+Q? The biggest ones of those have fairly sizable metal inner which you can take out (take out both the screws and slide the metal bit out)....
blakep82
posted on 24/8/09 at 06:06 PM Reply With Quote
^ interesting idea, but the cables would go through those the wrong way
clairetoo
posted on 27/8/09 at 05:52 AM Reply With Quote
1/4" is 6.35mm - to fit the bike carb it will need to be 6mm .
I use bike throttle cables - right end for the carbs/throttle bodies , and then make the pedal to suit (a tight nipple will soon break )
Its cuz I is blond , innit
Claire xx
Will weld for food......
blakep82
posted on 27/8/09 at 10:29 AM Reply With Quote
i have got the bike throttle cable out there, but i've also already got the pedal. it won't fit both.
i'll have a look to see if it'll work if i cut the nipple off the pedal end to but it round the pedal and throughone of those cable clamp things
or see what that bike shop in glasgow has. they do some general cable kits
