Author: Subject: Fireblade sump baffel plate wanted 893
ReMan
posted on 31/8/09 at 07:13 AM Reply With Quote
Now urgently need a baffel plate prior to trackday at mallory next Saturday, having been let down
Got one spare or know where to get one?
Colin
Dangle_kt
posted on 31/8/09 at 07:26 AM Reply With Quote
Mine is from AB performance, but last time I contacted Andy my order didn't arrive as he is rushed off his feet with more cars than you can shake a stick at. To be fair he knew it wasn't urgent and still took time to discuss a problem I was having on the car with me despite being manic busy.
Guess that doesn't help if you need it for Friday... but might be worth calling and explaining to see if he can accomodate a quick delivery?
mark chandler
posted on 31/8/09 at 10:23 AM Reply With Quote
Have a google for some pictures, bit of tin or thick ali and make your own, its easy enough.
Lay sump on chosen metal draw around with marker pen and cut out.
Dot the bolt holes, get a bolt which is a tight fit in the holes, sharpen the end to a point and mark so you can drill out easily.
Little measure up for the oil collector and return, cut holes for these then add a few more in from the sides a bit to drain.
Takes an hour tops.
Just use a smear of halfords instant sump gasket both sides to seal, no need to purchase gaskets.
Regards Mark
