Andy S
| posted on 4/10/09 at 08:01 PM |
WTD Pinto water pump pulley
Anyone got a Pinto WP pulley kicking around single or double.
mcerd1
| posted on 4/10/09 at 08:04 PM |
which type of pump ?
there different sized holes in the middle depending on the pump, the are ones for cars with power steering, viscous fans, etc.....
[Edited on 4/10/09 by mcerd1]
omega0684
| posted on 4/10/09 at 08:14 PM |
i will have one that is the viscous fan type when claire is finished making my poly V Billet pulleys, don't know how long it will be but
shouldn't be long, do you need it urgently?
Andy S
| posted on 4/10/09 at 09:22 PM |
Not an immediate urgency - Was not aware of hole sizes - its a 205 block so assume sierra pump I have no idea so will drop the vern across it.
omega0684
| posted on 4/10/09 at 09:49 PM |
my one should be ok for you, im running same setup, i will drop you a u2u when my pullys are done to see if you still need it.
gavin174
| posted on 4/10/09 at 10:15 PM |
i think it depends on the water pump
if its designed for viscous van the centre hole is 25mm
if early type solid fan 20mm...
