Author: Subject: front indicators
dunk3
posted on 12/10/09 at 06:07 AM Reply With Quote
front indicators
Hi all, has anyone got a pair of front indicators what they have passed the SVA or IVA with, that they dont need anymore.
mad4x4
posted on 12/10/09 at 06:47 AM Reply With Quote
I just used small bike ones (oxford range) on 5" extended Stalks. (made the extensions out of a bit of tube with a nut clamped into it at each end)
Hope this helpd.
Remember to put a bit of Ali behind the nut if you bolt to the fiberglass to give it strength and stop the f/glass flexing.
Ofcourse after the SVA the extensions "Fell off"
[Edited on 12/1010/09 by mad4x4]
Scot's do it better in Kilts.
dunk3
posted on 12/10/09 at 06:53 AM Reply With Quote
Hi mad4x4 have you got any pics
posted on 12/10/09 at 08:28 AM Reply With Quote
I went for some Land Rover ones held forwards on lengths of black 40mm waste pipe. At each end I made a flange of MDF (also painted black) which was bolted beneath the headlight support at the rear and which the indicator screwed into at the front.
Steve Hignett
posted on 12/10/09 at 08:32 AM Reply With Quote
Yours are great Ben, but they prob need to be further out than that on an MK.
I have a couple of extenders that I made that aren't being used at the moment. I think they are something like M10Fine on the outside to take a normal or aftermarket bike indicator and M10 normal on the inside to bolt to the nosecone...
Think I have a pic somewhere...
Dangle_kt
posted on 12/10/09 at 09:19 AM Reply With Quote
Steve I think said extenders are actually in my sva bits box.
Your welcome them back if they will be any use for project "x", or you can pass them on.
