Author: Subject: instruments
FazerBob
posted on 27/11/09 at 02:46 PM Reply With Quote
instruments
I'm looking for a set of clocks/instruments for my car's winter update.
Ideally 80mm speedo and tacho, plus 52mm oil,water etc. Preferably black faced, but others considered. New or excellent condition.
Bob
cd.thomson
posted on 27/11/09 at 02:48 PM Reply With Quote
Ah, I have a pair of black dials, speedo and tacho, but not as new I'm afraid
Craig
Mr Whippy
posted on 27/11/09 at 02:50 PM Reply With Quote
would an Acewell type look out of place, would be cheaper in the long run
blakep82
posted on 27/11/09 at 02:52 PM Reply With Quote
I've bought some RMD gauges, made by the same folk who do smiths gauges, but a lot cheaper
get them from rally design, when i got mine, speedo was £80, all gauges illuminated (despite what you may read on here)
________________________
Myke 2463
posted on 27/11/09 at 04:20 PM Reply With Quote
Check out ETB's advert in mags, mechanical speedo 80mm but wil prob change for electronic. £ 199 for all 5.
Mike.
[Edited on 27/11/09 by Myke 2463]
mad-butcher
posted on 27/11/09 at 08:47 PM Reply With Quote
I'm with Mr Whippy all the warning lights in a nice surround as well
tony
Angel Acevedo
posted on 27/11/09 at 08:58 PM Reply With Quote
+1 ^
I will be using an Acewell, they are working on a 8K RPM version for V8 users.
That plus:
- Oil Press
- Water temp
- Fuel level (somehow I wouldn´t like this one on the speedo/Tach)
- Volt meter.
For these four I´ll be using VDO white cockpit series.
What I like about Acewell is that they have six indicator ligths for the most used functions:
Turn, hazard, oil, high beam, neutral.
Regards
AA
PS: If they don´t come up with the 8K RPM version, I`ll be using: the ACE-2803-AB or the ACE2853-AB
http://www.electrosport.com/street/speedometers-series-2700-2800.php
FazerBob
posted on 27/11/09 at 10:38 PM Reply With Quote
some interesting replies, thanks guys. I did think about the acewell/ digi dash/ vapour etc type, but as I currently have a Capri 6 clock display mounted in the middle of my dash, I thought I would go for the individual gauges layout.
The tip about the RMD gauges sounds promising, I will give them a look.
I had a VDO set from ETB in my last kit, and must say that they (ETB) were a pleasure to deal with.
So thanks for all the info. I have something to get started on now.
Bob
Bob
blakep82
posted on 28/11/09 at 03:13 PM Reply With Quote
here's my RMD speedo fitted in my scabby looking dash
got a LCD display that light up green, needle lights up red, and white round the outside and numbers i think, can't remember, its not wired up yet. i just tested it when i got it.
the gauge to the left of it is RMD too, the one on the right is a TIM gauge, used to fill the hole
Angel Acevedo
posted on 6/12/09 at 07:35 AM Reply With Quote
Acewell Speedo
Originally posted by Angel Acevedo
+1 ^
That plus:
- Oil Press
- Water temp
- Volt meter.
Regards
AA
I have just received the Speedo,
IT IS TINY!!!
But that´s OK by me, this will force me to use a smaller steering column so it doesn´t look out of place.
Another plus is that I may fit Oil pressure and Water temp gages behind the wheel.
Volts and Fuel will be outside.
eventually I´lll have a Layout to show.
In the meantime...
Planning, Dreaming, Saving,
I may not be able to get to work in the car by late January.
posted on 6/12/09 at 10:31 AM Reply With Quote
Mike.
They will change it for electronic, if you give them a load more cash! Price difference between mechanical and electronic is substantial, almost £90 extra.
