Miks15
| posted on 22/12/09 at 10:05 PM |
WTD: broken MK indy nosecone and scuttle
i have an mk indy scuttle and a nosecone, they are both a great ft except needing to be bit wider (4 inches for the nosecone and 8 for the scuttle
so the plane was to cut out the middle section of a knakered scuttle and nosecone to keep the shape and cut mine in half and join the bits up.
So basically looking for a nosecone and scuttle thats no good to anyone.
orton1966
| posted on 23/12/09 at 09:40 AM |
Might be easier just to cut and spread
Believe it or not, it is possibly easier just to cut them in the middle, space them apart, bridge the gap on the outside with some flexible plastic,
then glass them from the inside. Once cured, remove the plastic, skim with filler and your done
Miks15
| posted on 23/12/09 at 10:32 AM |
that was the other plan, but i just wanted to make sure it had the right shape since its being widenend quite a bit, but i might go down that route
anyway.
