Author: Subject: Wanted Pierburg carb from 1.8 Pinto (Sierra)
AdrianH
posted on 29/12/09 at 09:42 PM Reply With Quote
Just thought it worth another try.
Not after the a carb from the CVH but from the Pinto, Pierburg type according to book part number 85HF 9510 AB
Basically after the jets from the carb so generally knackered one should be fine. I get the impression most exchange them for Webers so are probably binned years ago.
Adrian
Why do I have to make the tools to finish the job? More time then money.
ashg
posted on 29/12/09 at 09:52 PM Reply With Quote
pm dogwood i think he may have one kicking about
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
AdrianH
posted on 29/12/09 at 09:58 PM Reply With Quote
Hi Ash
Is he not in France? Postage would be a bit.
Will send a message if nothing closer comes along.
Adrian.
P.s. just managed to pick up the magazine, good article. Even I got a mention near the front of the mag!
[Edited on 29-12-09 by AdrianH]
ashg
posted on 29/12/09 at 10:05 PM Reply With Quote
yeah knew you were in it ian told me when we were having a chat on the phone. well done, i may be bending your ear for tips at the end of he month. i think the spare carb dogwood has is sitting on his workbench in the uk. has to be worth asking. im sure i could go get it for you. i have the carb off my 1.6 kicking about but i cant remember what it is.
dogwood
posted on 29/12/09 at 10:07 PM Reply With Quote
Hi Adrian
Yes I am in France,
And yes I do still have a carb knocking about in the uk.
If you get compleatly stuck I could probably help you.
What exactly are you looking for?
I could probably get my wife to drop it over to Ash in a couple of weeks for him to pull apart.
FREE THE ROADSTER ONE…!!
AdrianH
posted on 29/12/09 at 10:14 PM Reply With Quote
Just sent you a pm on Haynes!
I need two pcs sometimes to watch both.
I am after the jets from it.
This is leading on from the rolling road session I had, where it leans out at 4,300 rpm under full load.
reading the book the rest of the engines had a 130 jet where as the CVH a 105.
I have a spare carb I have fitted and when the weather improves I will try it out, but if fault still there want to up the jet sizes in the secondary port.
It may be the fact I have a lot less restriction with the air filter.
Adrian
p.s. If I could find out the hole sizes for the jets I would drill some out!
p.ps. The article was Chris's idea, not mine.
ali f27
posted on 30/12/09 at 08:31 AM Reply With Quote
carb
think i still have the one off mine will have look later
