Author: Subject: Hayabusa throttle bodies
omega0684
posted on 13/1/10 at 07:11 PM Reply With Quote
im after a set of 45mm hayabusa throttle bodies ( there on the 1300 model i believe) , as new as possible, if anyone knows of anything let me know
Alex
yorkshire-engines
posted on 13/1/10 at 08:21 PM Reply With Quote
Oh i think might have around 10 sets in stock
omega0684
posted on 13/1/10 at 08:27 PM Reply With Quote
u2u to you Mr Yorkshire engines!
flak monkey
posted on 13/1/10 at 08:39 PM Reply With Quote
Why? lol
Pinto head ports are only 38mm dia....which is big enough for monster power!
Sera
http://www.motosera.com
omega0684
posted on 13/1/10 at 09:13 PM Reply With Quote
who said anything about a pinto, lol
race heads arn't 38mm inlets are they? i know for sure they use 45.5/46mm inlets cuz i've got them, arn't the inlets opened up so that you have 45mm running all the way threw to the valve
flak monkey
posted on 13/1/10 at 09:44 PM Reply With Quote
Race Inlet valves are 44.5mm od. Stds are ~42mm IIRC
Ports themselves are nowhere near that diameter though.
The ports are virtually always retained at 38mm diameter on all race heads I have seen. The optimum valve size for that port is still larger than can be fitted to a pinto head (~47.5mm IIRC)
Hence why even most race engines only run 45 or 48 DCOE carbs with max 38mm chokes fitted. Anyone fitting 50's does it purely for poser value and no real performance gain
[Edited on 13/1/10 by flak monkey]
Sera
omega0684
posted on 14/1/10 at 12:17 PM Reply With Quote
looks like im going to have the get the vcalipers out and get measuring!
THANKS FOR THE SOUND ADVICE DAVE
