Author: Subject: Bulk Soda ash wanted 25 kg
mangogrooveworkshop
posted on 13/1/10 at 10:18 PM Reply With Quote
http://www.sodablaster.co.uk/index.html
sodium bicarbonate
we want to blast some shells so we need a pallet of it
Where can we get large sacks from?
[Edited on 13-1-10 by mangogrooveworkshop]
posted on 13/1/10 at 11:42 PM Reply With Quote
A good kick in the nads might do it What kind of shells are you blasting ? You'll need something a lot more abrasive than baking powder if you want to remove rust and paint unless you have a really good compressor and drying system, it works on oily metal like zinc or aluminium but rusty steel is going to need a lot more bulk.
[Edited on 13/1/10 by Peteff]
mangogrooveworkshop
posted on 14/1/10 at 12:02 AM Reply With Quote
He uses one of these
We have two sierra shells requiring blasting.
Our blasting man has a large compressor and very heavy grit to do the chassis.
The Soda is just to do the painted panels and joints
We have had stuff done a few times but he only has the heavy media.
Hence the need to aquire it.
wonder if Andy has some used garnet going next time he cleans the bed out?
Angel Acevedo
posted on 14/1/10 at 03:42 AM Reply With Quote
Drilling Additives
Any Drilling Mud Additive place??
posted on 14/1/10 at 10:37 AM Reply With Quote
Try sugar, it's going to be expensive though. A friend of mine used to use crushed walnut shells when he was blasting but he's retired now. See if these will send you some up.
posted on 14/1/10 at 12:29 PM Reply With Quote
And surely create a sticky syrupy mess if there is any moisture around?
CNHSS1
posted on 14/1/10 at 02:20 PM Reply With Quote
Try Pometon in Telford, shropshire, they are blast media distributors.
not sure if they do sodium bicarb, but be surprised if they didnt or could put you onto a trade supplier.
Craig
posted on 14/1/10 at 03:09 PM Reply With Quote
Crush walnut shells or cherry stones are the usual choice for delicate stuff, I know when I worked for BAA 16 or so years ago we bought it from a major Iron monger/engineers merchant.
Confused but excited.
posted on 14/1/10 at 06:33 PM Reply With Quote
Soda Ash is Sodium Carbonate.
You want Sodium Bicarbonate.
These people make it; http://www.brunnermond.com/
IMS minimum order 1Tonne.
HTH.
