Author: Subject: WTD/Borrow carb synchronometer
stuart_g
posted on 19/1/10 at 10:34 AM Reply With Quote
Has anyone got a carb synchronometer/balancer I could borrow please? I need to balance the throttle bodies on my Zetec.
[Edited on 19/1/10 by stuart_g]
Danozeman
posted on 19/1/10 at 11:07 AM Reply With Quote
I have one of them gunsons ones that do 1 carb at a time if its any use. I did my carbs ok with it.
Dan
DaveFJ
posted on 19/1/10 at 01:15 PM Reply With Quote
I also have one of the Gunsons jobbies if you want
Dave
will121
posted on 19/1/10 at 05:25 PM Reply With Quote
have you still got the vacuum tappings on your throttle bodies where you can connect a £5 DIY U tube manometer?
stuart_g
posted on 19/1/10 at 05:42 PM Reply With Quote
Yes there are brass tubes on the bottom of every TB.
More details of your invetion please.
will121
posted on 20/1/10 at 08:38 AM Reply With Quote
afraid not my invention more info hereDIY U Tube
i filled mine with light 5W oil so offered bit of damping and didnt need to be so tall. idealy needs two people because if ballance is miles out to start with risk of sucking all the oil out,
Principal is connect one end of tube to datum cylinder (end with throttle cable connection) and other end to second cylinder, start engine watch levels of oil, (turn of engine if getting to high or adjust quickly!!) adjust butterfly balance screws till liquid levels same both sides, turn off engine, leave one end connected to cylinder 1 move other to cylinder 3 and repeat, again cylinder 4. generally once ballanced tick over will raise, adjust main tick over and repeat to confirm ok, may require further minor adjustments again. one main thing to remember is turn off engine before disconnecting any end of the U tube.
907
posted on 20/1/10 at 09:27 AM Reply With Quote
I have a set of 4 gauges as used on bikes.
They were brand new, left in my garage by a bloke that wanted to do the job here.
Then he sold the bike.
Said he didn't need them any more. (shrug)
Paul G
