Author: Subject: Need a 1.8 silver-top zetec sump and pick up pipe
dan8400
posted on 25/1/10 at 10:29 AM Reply With Quote
As per the title. Can anyone help? I thought the escort sump would be short enough but guess what. lol
OR is there a steel replacement i can mod myself (ie: will black top steel sump fit silvertop???)
Dan
[Edited on 25/1/10 by dan8400]
martin1973
posted on 25/1/10 at 10:41 AM Reply With Quote
do u want a standard sump to mod?
martin
UncleFista
posted on 25/1/10 at 11:34 AM Reply With Quote
The Mondeo 1.8 sump is deeper than the Escort one I'm afraid.
Deneo on here can help you out
[Edited on 25/1/10 by UncleFista]
Tony Bond / UncleFista
Danozeman
posted on 25/1/10 at 11:49 AM Reply With Quote
the cvh steel one fits with slight modification to the block. You need to drill and tap a couple of holes in the block.
Dan
dan8400
posted on 25/1/10 at 11:59 AM Reply With Quote
If it were steel i could mod it. If it's ali i can't. CVH steel one sounds like an option.
Is the pinto one the same by any chance? Could re-use the one i'm chucking out...
Also is the black top steel sump?
Dan
whitestu
posted on 25/1/10 at 12:53 PM Reply With Quote
Blacktop sumps have a lower steel pan that is easy to chop. I've never done it, but I don't think it is a straight swap onto a silvertop.
big_wasa
posted on 25/1/10 at 07:08 PM Reply With Quote
I dont think the black top sump will fit as the bearing caps are 20mm lower on the silver top. I have one if you want to offer it up and have a look.
1.8 cvh will sort of fit but the newisr one is around 18 years old so not the best start to weld up. Ive fitted a couple.
You will need the spreader plates and pick up pipe that goes with it.
They are not easy to come by.
dan8400
posted on 27/1/10 at 07:14 AM Reply With Quote
I have the standard Escort sump. It's shorter than the mondeo one but not quite short enough... can it be cut and shut?
Dan
