Author: Subject: R1 5vy ignition lock transponder sender
Davg
posted on 2/2/10 at 09:16 PM Reply With Quote
Anyone got an immobilser transponder unit surplus?
The unit is attached to the steering lock barrel by 2 torx screws.
unit I have has got very minor damage & not sending signal to ECU.
or if poss anyone willing to lend a working unit to test?
Cheers thanks
D
Image deleted by owner
[Edited on 2/2/10 by Davg]
yorkshire-engines
posted on 2/2/10 at 09:57 PM Reply With Quote
Problem here the R1 transponder arial is also chipped same as the key and ecu
so they dont interchange you can get another arial and remove the chip from damaged one and insert into the new one then it will work
what year is the motor
cheers malc
Davg
posted on 2/2/10 at 10:31 PM Reply With Quote
Thanks Malc, I think!
The motor is a 2006.
cheers D
