Author: Subject: type 9 housing bolts
goaty
posted on 7/2/10 at 11:20 AM Reply With Quote
hi,
can anyone help me.....
I was about to bolt a bellhousing to my type 9 as its my run in gearbox, but i have found the standard bolts that are for bolting it to the Gbox are too short.
Anyone know where i can get longer ones as they are nto standard metric thread by the looks, seems finer.
thansk in advance
joe
flak monkey
posted on 7/2/10 at 11:38 AM Reply With Quote
Type 9 box bolts are either standard M12 or are 1/2" UNF if I remember rightly.
Sera
http://www.motosera.com
posted on 7/2/10 at 11:46 AM Reply With Quote
Standard M12's, easy to get from any fastener place.
goaty
posted on 7/2/10 at 12:00 PM Reply With Quote
cheers dave, must be 1/2 unf as they def not M12.
will try to track some down asap.
thanks again
posted on 7/2/10 at 12:26 PM Reply With Quote
Get yourself a set of threads gauges (£3 or £4 ) and measure the bolts you have . Likely to be 12mm x1.5?
dave r
posted on 7/2/10 at 12:55 PM Reply With Quote
definitly metric 12mm
put some in mine this morning
omega 24 v6
posted on 7/2/10 at 01:04 PM Reply With Quote
Mmm I'm sure mine were 12mm fine pitch and a bugger to find locally. There is a guy on ebay flogs them
Ask him if he can supply the length you need.
here
goaty
posted on 7/2/10 at 05:49 PM Reply With Quote
a friend can measure it for me, i am hoping to see him 2mo, but it definetly a fine thread bolt.
i will put up 2mo if i see him.
cheers
goaty
posted on 8/2/10 at 11:21 PM Reply With Quote
there are m12 1.50
now just gotta find some, anyone know a good supplier?
thanks
