Author: Subject: wtd: brake fluid hose
cd.thomson
posted on 14/2/10 at 06:35 PM Reply With Quote
anybody have some left over? i bought fuel hose as i thought that would be resistant
Craig
gavin174
posted on 14/2/10 at 06:37 PM Reply With Quote
are you after solid copper pipe..
or flexible hose?
Russbost is your man for flexible.
cd.thomson
posted on 14/2/10 at 06:38 PM Reply With Quote
oh sorry, flexible.
its just to connect my resevoir to my master cyclinders
Craig
Miks15
posted on 14/2/10 at 06:50 PM Reply With Quote
I think youll need to buy it from a supplier, because mine came with a certificate to say it was ok for brake fluid
got mine from cbs
wicket
posted on 14/2/10 at 07:43 PM Reply With Quote
Mine are Fiat Seicento hoses.
A couple of pictures in my archive of marked hoses. The longer one is p/n 46774776, 290mm long, and the other is p/n 46774775, 220mm long. Total cost £8.48 inc vat (5 years ago).
If I had known I would have just bought 2 of the shorter ones, they are just the right length.
posted on 14/2/10 at 07:49 PM Reply With Quote
Think Automotive sell the correct hose.
stevegough
posted on 14/2/10 at 07:53 PM Reply With Quote
So did I - I have fitted mine with high pressure fuel hose - is this no good for brake fluid?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
stuart_g
posted on 14/2/10 at 08:15 PM Reply With Quote
Get the blue braided hose from Merlin motorsport, they will also send you the print out of spec for SVA/IVA.
GeorgeM
posted on 14/2/10 at 08:22 PM Reply With Quote
CBS sell it, dark blue colour.
Fuel hose will leak
GeorgeM
My conscience is clear - I drive a GREEN car
MNR Racing
essexkitcarclub.com
cd.thomson
posted on 14/2/10 at 08:27 PM Reply With Quote
hi steve, apparently something in brake fluid will eat through fuel resistant hose and you wont pass IVA with it
Craig
stevegough
posted on 14/2/10 at 09:08 PM Reply With Quote
Hello Craig
- I'm glad I found out before I filled the system up with brake fluid. I have got two pipes (ex british leyland Marina clutch master to slave cylinder hose - marked up lockheed - clutch). I think they will be better?
Hows your build going?
Luego Locost C20XE.
MikeR
posted on 14/2/10 at 10:47 PM Reply With Quote
bought mine at a show a couple of years ago and never got the letter - now can't remember who i bought it off to ask for the letter. Suspect it was CBS. Can anyone send me a copy of the letter if i double check the codes on the pipe?
