macc man
| posted on 8/3/10 at 08:30 PM |
Vibration
Is it common to have a lot of vibration on tickover in seven style cars. I have used heavy duty rubber engine mounts and rubber exhaust blocks. I was
thinking of softening things up. Any thoughts?
blakep82
| posted on 8/3/10 at 08:32 PM |
man up!
don't know if its normal, but i'd think it is. in the short times i've had my pick up running there's been a LOT of vibration
though.
i certainly wouldn't worry about it
________________________
Madinventions
| posted on 8/3/10 at 08:37 PM |
Just get a comfy seat and some noise cancelling headphones?
Oh, and keep the revs up!
Job done.
Ed.
View my band website:
http://www.shadowlight.org.uk
Richard Quinn
| posted on 8/3/10 at 10:03 PM |
I've got an Aprilia v twin solid mounted in mine. It's not that bad (compared to a road breaker!). All part of the "charm"!!
macc man
| posted on 8/3/10 at 10:08 PM |
Thanks for the replies, maybe I am being over critical. It will be used mainly for track use but would be tiring on any long journeys.
flak monkey
| posted on 8/3/10 at 10:14 PM |
Yep tickover vibration is pretty normal, wouldnt worry though, just make sure everything important is still tight after 100 miles
Sera
http://www.motosera.com
blakep82
| posted on 8/3/10 at 10:19 PM |
more importantly, it looks like you want vibration, as its in the wanted section
just noticed that as i was making a new wanted thread
mangogrooveworkshop
| posted on 8/3/10 at 10:23 PM |
try a hard mounted bec with no rubber mounts between engine and diff....    just hard core. The vibration is ok and will go away as bits of
your body gradually lose feeling .....linky
