Author: Subject: Threaded Bar
Badger_McLetcher
posted on 9/3/10 at 07:53 PM Reply With Quote
Threaded Bar
Hey guys, I'm after a piece of bar stock about 40mm (could go down to 20mm or larger though) in diameter with a screw thread on it for a project I'm working on. Doesn't need to be very long, only about 30-50cm.
Don't suppose anyone's got some laying around they can sell me, or knows where I can get some? I've tried Ebay too but not sure what to search for, the only stuff I've found is too small diameter.
If disfunction is a function, then I must be some kind of genius.
boggle
posted on 9/3/10 at 07:56 PM Reply With Quote
have you tried searching for studding???
or speak to flak monkey...
u2u me for details
posted on 9/3/10 at 07:58 PM Reply With Quote
what grade?
something like this?
http://www.orbitalfasteners.co.uk/details/M20x55-Hex-Set-Screws-High-Tensile-8.8-Bright-Zinc-Plated-2008.html
then saw the head off.
thye sell studding M24, M27, M30, M33, M36, M42
doddy
posted on 9/3/10 at 08:29 PM Reply With Quote
here is m30
http://cgi.ebay.co.uk/Mild-Steel-BZP-Threaded-Rod-M30-x-1-metre_W0QQitemZ110451677428QQcmdZViewItemQQptZUK_DIY_Material_Nails_Fixing_MJ?hash=item19b76 ed8f4
Badger_McLetcher
posted on 10/3/10 at 12:27 AM Reply With Quote
Cheers guys, that should do the jobby
welderman
posted on 10/3/10 at 09:02 AM Reply With Quote
might have some bolts and you can cut one down, back in a rolly mo
Joe
Thank's, Joe
I don't stalk people
