Cita
| posted on 23/5/04 at 07:14 AM |
3/4" bolts
I need some 3/4" bolts approx.4" long and jam nuts for female rod ends.
The thread is 16 TPI.
Anybody got some or know where to get them?
Thanks!
| posted on 23/5/04 at 08:55 AM |
I don't think I've ever seen any that big on a car. What are you using them on?
Cita
| posted on 23/5/04 at 09:56 AM |
Pete,
i know it's a "bit" overkill as intended to use them in the suspesion but i'm working on some unusual settings hence the use
of the size plus the fact that these rod ends were a bargain.
Tblue
| posted on 23/5/04 at 10:37 AM |
3/4" unf (for it is them) bolts should be available from all good bolt factors, as should the nuts. Maybe even lenghts of threaded bar.
Although with you being in Belgium I can see a slight problem. Any good British bolt factors will have them, you'll probably have to have it
sent over.
[Edited on 23/5/04 by Tblue]
theconrodkid
| posted on 23/5/04 at 01:14 PM |
try orbital fastnings,they have a website somewhere and are well cheap
who cares who wins
pass the pork pies
Hornet
| posted on 23/5/04 at 03:07 PM |
I'll see if i have any at work on Monday..
If there are you can have them. How many you need?
Cita
| posted on 23/5/04 at 07:00 PM |
Hornet you have U2U
Terrapin_racing
| posted on 24/5/04 at 08:36 AM |
try
http://www.allfix.co.uk/index.htm
cheers
Rob
Cita
| posted on 24/5/04 at 08:44 PM |
Thanks for the pointer Terrapin!
Hornet
| posted on 25/5/04 at 11:13 AM |
Lo cita
Sorry, none at work.
Cita
| posted on 25/5/04 at 12:16 PM |
No worries mate
Thanks for looking!!!!
