Author: Subject: Wanted:Lightened Zetec Flywheel
RichardK
posted on 23/8/10 at 08:55 PM Reply With Quote
Preferably one that will take the pinto clutch etc like the tiger racing one although will consider anything if the price is right.
What have you got?
Rich
Gallery updated 11/01/2011
big_wasa
posted on 23/8/10 at 09:05 PM Reply With Quote
you could try scholar engines I got mine cheap from them. But it was years ago.
austin man
posted on 23/8/10 at 09:06 PM Reply With Quote
why not use the 1.8 flywheel and zetec clutch
RichardK
posted on 23/8/10 at 09:16 PM Reply With Quote
Think the original 2l mondeo is 9.9kg, the 1.8 is 8.8kg and the proper lightened ones are about 6.5kg. Which should make a noticeable difference even over the 1.8
The dunnell one is £95 although do need another plate and cover which is another £90, the tiger one uses the pinto clutch and cover and is £145.
However if a 1.8 came along at the right price my wallet does tend rule over my head!!
Rich
RichardK
posted on 23/8/10 at 09:17 PM Reply With Quote
I'll give them a call as I can't see any ref on the website that they still do them.
Rich
Dusty
posted on 23/8/10 at 09:37 PM Reply With Quote
Retro Ford do 1.8 flywheels ready drilled for pinto bits. £84.
[Edited on 23/8/10 by Dusty]
madteg
posted on 23/8/10 at 09:42 PM Reply With Quote
I am using a 1600 zetec escort flywheel redrilled to fit pinto clutch so i could put a 5 point paddle clutch on it, works a treat.
[Edited on 23/8/10 by madteg]
RichardK
posted on 23/8/10 at 09:45 PM Reply With Quote
Thought that was a standard one ie 9kg, the lightened one is £230, maybe wrong though.. Have you had one is is it lighter as it doesn't have any weights on it.
Rich
RichardK
posted on 23/8/10 at 09:48 PM Reply With Quote
Mmmm, only seems to be focus 1.6 zetec ones on the bay at the moment, does anyone know if they are the same?
Rich
whitestu
posted on 24/8/10 at 07:31 AM Reply With Quote
1.8cvh flywheel is 6.5kg, but most don't have trigger wheels. Very locost though and fitting a front trigger wheel is easy.
Stu
Danozeman
posted on 24/8/10 at 07:45 AM Reply With Quote
Scholar do an exchange one which is a standard one ground down so still takes standard zetec clutch and ring gear is in the same position. Think its 100 quid.
Dan
RichardK
posted on 24/8/10 at 09:23 AM Reply With Quote
Thats part of my problem as I had an auto boxed mondeo so don't have a flywheel to exchange.
Rich
