karlak
| posted on 9/9/10 at 10:32 AM |
Throttle position Sensor for DHLA carbs
Now I have got my Pinto converted to Megajolt, I could really do with going for a 3D map.
Has anyone got a Throttle position sensor suitable for twin Dellorto DHLA carbs lying around ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
r1_pete
| posted on 9/9/10 at 10:42 AM |
I made one for my DCOEs, very simple using a ford sensor.
Taken them off the car now so will get you some pictures if you like.
I turned a piece of Hex bar down and threaded it to replace the shaft screw on one end, then filed flats on it to drive the TPS, total cost was about
£10, compared to over £70 for the webcon version.
karlak
| posted on 9/9/10 at 11:32 AM |
Cheers Pete, Ideally i was hoping for something "ready to go" - Do you still need yours that you removed, but pictures would be great
also
I am wanting my car tuned early next week and will not have time to make something in the meantime. The price they want for the kit is shocking
dhutch
| posted on 9/9/10 at 11:53 AM |
Can lay my hands on a photo of it while im at work, but i made the braket for mine in about 15minutes from a short (2-3inch) lenght of ali angle.
Picking up the two mounting holes of the TPS and the one in the side of the carbs.
The TPS i used was of a vauxhaul but only because it was adjacent to the ford i was taking the coil pack of and had its bonnet open!
You do need a lathe at a M7 tap to make the spindle adapter, but again, for anyone with a lathe its a 20minute job tops. I just made a barrel section
the screws onto the end of the spindle, retained with lock tight, and a bit of 8mm bar with a flat in it grub screwed into that to locate onto the
TPS.
But no, in short, i dont have a spare! Sorry.
Daniel
Alan M
| posted on 9/9/10 at 12:06 PM |
I've got a new Webcon one, 'cos I only used their bracket. What's it worth?
r1_pete
| posted on 9/9/10 at 04:18 PM |
Here's a coule of pics:
Image deleted by owner
This addiional bracket is used to position the sensor, then drill the 2 holes and fix permanently.
I've no idea whether the DHLAs have the same mountings, let me know if you need any more info...
[Edited on 9/9/10 by r1_pete]
karlak
| posted on 9/9/10 at 05:49 PM |
Cheers guys - I now have something to go on. I have found a "shaft" with the correct size thread. Will stop at the scrappies tomorrow to
pickup a Sensor and then get inventive for a mounting solution.
My DHLA (E) carbs only have one mounting hole where the ones above (and othe DHLA's) have two, but I am sure I can get something sorted
