Cozza
posted on 19/9/10 at 08:37 PM |
Starting a C20XE
Hi folks,
Bought a part-built kit recently with a red top in it. The engine and Manta gearbox are mounted. I don't really know the condition of either.
What's the minimum I need to connect up to run the engine? I've got an ECU but not convinced it's the right one. Any advice
greatly received!
Cozza
matty h
posted on 19/9/10 at 09:51 PM |
Is the ECU a standard vauxhall item if so tell me the 0 200 number off it a I should be able to tell you what it is from.
matty h
Cozza
posted on 19/9/10 at 10:14 PM |
Thanks Matty! I'll get the code tomorrow.
Cozza
Cozza
posted on 20/9/10 at 05:40 PM |
Some details from what I believe is a standard Bosch ECU:
2-row connector made up of 1 row with 17 pins and 1 row with 18 pins
Part number 0 265 100 029
Serial number 8479906
Any thoughts?
posted on 20/9/10 at 07:04 PM |
Sounds like an ABS ECU for
a Rover 800
ECU numbers for C20XE
[Edited on 20/9/10 by MikeRJ]
matty h
posted on 20/9/10 at 08:33 PM |
Can not seem to find that part number.I believe all c20xe engines have 3 rows of pins on the ecu.So you could be right in thinking it is not the
correct one.Are you intending on running the standard injection.
Cozza
posted on 20/9/10 at 08:34 PM |
You're joking! That's not gonna start my car then lol. What to do? Go down the programmable ECU route?
posted on 21/9/10 at 03:49 PM |
Either find a compatible Bosch ECU, use an aftermarket system (Omex, Emerald, Megasquirt etc.) or bolt some of those prehistoric carbs on the side.
Cozza
posted on 21/9/10 at 09:34 PM |
Thanks. I'm thinking about going down the route of Weber 45s of bike carbs. Won't I need an ECU of some sort for the ignition side?
matty h
posted on 21/9/10 at 10:29 PM |
Your options are get a standard vauxhall ecu for your engine will need engine if you do not have one will be cheapest but would of thought that
stanard injection will not fit under the bonnet.
Option 2 is to fit carbs bike or webers you would then need something to control ignition a h and h distributor,old cavalier one or ignition only ecu
like megajolt.
The best option but also the most expensive is throttle bodies and fully programable ecu.
matty h
posted on 21/9/10 at 10:31 PM |
Edit last post you will need a engine loom NOT A ENGINE.
Cozza
posted on 22/9/10 at 07:57 PM |
Thanks Matty H. There is a wiring loom with the engine. I think it's complete. I take it that I would need an ECU along with the key
transponders?
laptoprob
posted on 25/9/10 at 07:24 AM |
Been there and done all that over the past year mate. Injection wont fit so forget that one. For easyness go 45`s and an old MBE ecu if you can find
one(912,956 etc). If you look on recent posts there is a chap going C20LET and will be binning the 956. Mail me if you want to know anymore or need
anything.
