Daddylonglegs
| posted on 31/5/11 at 09:54 PM |
English Axle Breather
Thought I'd try in the Wanted section instead of tagging it on the end of a running gear one
I'm after a breather for a an English Axle as mine seems to have found a better home
Any ideas chaps and chapesses?
Ta
| posted on 1/6/11 at 07:34 AM |
you are gonna struggle finding one.
breather from Land Rover axle can be made to fit - I glued mine in as, if I recall, the hole in axle is slighlty larger than the breather.
Daddylonglegs
| posted on 1/6/11 at 10:39 AM |
Thanks mate
blakep82
| posted on 1/6/11 at 11:48 AM |
when i re-tubed my atlas axle, i ended up drilling a hole in the tube, welding (glueing could work too) on a nut from an air line fitting, and
screwing in a male PCL fitting to attach a hose/tiny filter to
might work for you too?
weld/glue this on
Air Line Nut 1/4 BSP Pack of 2 for use with 1/4 tail | eBay UK
scrw that in
DRAPER AIR TOOL COUPLING ADAPTOR PCL MALE 1/4' BSP * | eBay UK
[Edited on 1/6/11 by blakep82]
________________________
